![]() | Home > Maintenance & Modifications > Best way to wire light bar |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Best thing to do is wire the main beam trigger wire through the carling switch. If the switch is on then the light bar will illuminate with the main beam and if it's off then it won't
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Then use power via the blue sea fuse box to a relay controlled by said switched trigger
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
Ah sounds like a good idea
![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Probably the high beam tell tale wire behind the dash
