Home > Maintenance & Modifications > steering damper (up-rated worth it) and Panhard poly bushes?
Stacey007
Hello
Following from my wheel spacers thread, My car is due for a service before we head off on our summer holidays.
While its its in the guy said he will swap the spacers front to back to check.
In the mean time I might source a new steering damper and panhard rod bushes.
I'm on nearly 80K now so the original stuff probably is a bit worn?
Is it worth getting an up rated steering damper? if so which one, I noticed a terrafirma one ?
https://www.johncraddockltd.co.uk/accessor...ab-sh.html
The the Panhard rod bushes?
Is it worth going Poly for these?
http://www.paddockspares.com/anr3410p-poly...-bush.html
As I changed bits on the car I've generally been upgrading the parts so what ever people think?
Thanks
Post #631886 16th Jun 2017 9:56pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
I think feeling that the poly is only for race cars on circuit. It is my opinion only but for a defender i imagine rubber originals are better for comfort. Poly will allow noise and vibration.
RTC steering damper is a help for off roading but on road not nececarry and perhaps annoying. Bilstein B6 sterring damper from Alive is my choice and it made the steering very soft and enjoyable.
Post #631891 16th Jun 2017 10:15pm
For info, I am well over 200k miles now and still on all original bushes and steering damper. I see no reason why the fact you've done 80k should necessarily mean yours are worn out.
Post #631895 16th Jun 2017 11:28pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I fitted superpro bushes to the panhard on my previous 110 and it did make a positive difference.
Are you sure the bushes in your link are correct for a tdci?
Flat dog have a good price on a old man emu damper at the moment.
Post #631904 17th Jun 2017 7:02am
zsd-puma
Isn't the steering damper just there to stop the wheel getting snatched out of your hand when driving on rough roads?
I wouldn't have thought you really "need" one on tarmac roads, so an 'uprated' one would seem a bit pointless?
Post #631921 17th Jun 2017 11:41am
ARC99
Having read your other thread about the wheel wobble I started to think back to when I had wheel wobble on A classic Range Rover and a Disco 1. I changed to steering damper and it stopped although the one on the Disco failed after 2 months which I swopped out and replaced with a Bilstein damper.
The current 110 has had all the suspension and steering damper swapped out for Bilstein's. Don't make old people mad.
Richard
Post #631930 17th Jun 2017 1:04pm
bear100
Just bought a Bilstein B6 Return to centre steering shock, heard good reviews on it Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #631998 17th Jun 2017 9:56pm
Really? I've yet to hear a good thing said about any RTC steering damper, and to be honest don't see the point.
It would be interesting to hear your impressions when you've fitted it.
Post #632141 18th Jun 2017 9:39pm
