Home > Technical > rear axle - 90 axle on 110?
Nige71
United Kingdom 1997 Defender 110 V8 Petrol CSW Nato Green
Hello All
Will a 1985 defender 90 300tdi rear axle fit 1997 110 v8 .
Thanks Nige
Post #629599 7th Jun 2017 7:05am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I assume you have the dates the wrong way round, not sure if a 90 axle has a lower load rateing than the 110. Also I think the 110 has a larger rear springs so you would need to change the spring seat. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #629600 7th Jun 2017 7:24am
There's no such thing as a factory 1985 300tdi, so if that's what you've got then the engine is a retrofit. Regardless though, 90 axles of any vintage are not suitable for a 110 as the latter have bigger springs and heavier duty diffs. Darren
Post #629613 7th Jun 2017 9:03am
Nige71
Thanks for the info have not brought the axle yet so will let the bloke know I it won't fit.thanks nige
Post #629617 7th Jun 2017 9:50am
Gilloverland
I'm going to fit a Discovery rear axle to my early military 110.
- It gets rid of the clunky Salisbury ground anchor
- Its an instant upgrade to disc brakes (but Ill be changing the master cylinder and bias valve)
- Its cheaper and easier to fit a locking / atb diff.
I don't buy into all the 'its not rated' BS, I've had discoveries before, given them some serious punishment and loads and never had any problems with the axle, neither for that fact did the Camel Trophy ones and they're a lot heavier than my 110 will ever be.
I think its more important to sort out the braking differences between Drums and Discs so you don't end up with overly powerful rear brakes!
Post #670454 12th Dec 2017 9:51am
Might be BS to you... but, if you have an accident/cause on, and the authorities start poking at your truck and realise you've got the "wrong" axle on it, don't come crying here...
Post #670571 12th Dec 2017 7:13pm
bankz5152
There was a fella not too long ago that had "wrong axles" on a 110 (cant quite remember but I think they where Disco axles), something gave way on the rear and sent the 110 to the bottom of a lake with him in it.
Afaik 110s have short nose or salisbury diffs fitted, not long nose diffs which 90s have. So the props probably wouldnt fit.
Why not just get the correct axle for your car?
That said it is common to fit D2 front axles to challange trucks and the like
Post #670577 12th Dec 2017 7:50pm
Also, Land Rover didn't develop a stronger axle just for the fun of it Rolling Eyes Darren
Post #670579 12th Dec 2017 7:56pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Is the D2 front axle an upgrade over the normal 110 front axle?...and are they a strait swap?
Patrick
Post #670595 12th Dec 2017 9:26pm
Gilloverland
I'm aware of that case but the issue wasn't the 'axle' it was the brakes. AFAIK it was a RRC disc brake rear axle but the master cylinder and valves etc had been left original which basically biased the brakes to the rear rather than the front causing a loss of control under heavy braking.
Any change from drum brakes to disc on the rear axle (Salisbury / wolf / disco etc) should include the relevant master cylinder.
Post #670630 13th Dec 2017 8:03am
DSC-off
"Is the D2 front axle an upgrade over the normal 110 front axle? And are they a straight swap?"
Patrick,
No the D2 axle is not a straight swap into a 110.
The D2 used different radius arms, so it would need some specialist fabrication to modify the axle, or make new radius arms to connect it to the chassis.
Also the panhard rod position is different, again needing specialist modification.
D2 axles use a different pattern for the hub bolts, that will mean different wheels, front and rear.
As some wise people have said above, using the correct type axles for the vehicle is the safest and easiest option for a road vehicle.
[/quote]
Post #670758 13th Dec 2017 8:11pm
bankz5152
Ahh thanks for clearing that up! I couldnt quite remember!
Post #670777 13th Dec 2017 9:19pm
