Home > Maintenance & Modifications > Front hockey stick bush play
excossack
Is this too much play in the front hockey stick bushes?
On a quest to remove some vagueness in the steering and some tramline type noise on some roads.
Found these bushes had play and also one of the steering ball joints knocks a bit. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #628861 4th Jun 2017 12:02pm
benniferj
Err.. yes definitely. They're totally and completely shot.
Good news is that bushes are cheap - get some proper genuine ones and if you don't have a press, go to your local garage and ask them to do it. The arms are easy to take off... 3 bolts per arm. Make sure you've got a big socket bar to help crank them off. Do the push in bushes at the axle end at the same time too.
Post #628862 4th Jun 2017 12:38pm
excossack
I thought so. Might explain some vagueness.
Might as well do three bushes per arm. And no press in my shed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #628866 4th Jun 2017 1:07pm
benniferj
Im sure it can be sorted at your friendly local small garage... Will make a world of difference.
If the ball joint ends are a bit worn replace all 3 as well - or pick up something decent like the Terrafirma HD steering arms package as they are super easy to adjust and pretty cheap too. Fully greaseable.
Post #629044 5th Jun 2017 9:05am
excossack
I have all three to replace as well as I found one (the front N/S) was knocking and has some play.
With the new bushes and new ball joints it will feel like a new car! 1999 Defender TD5 110
Regards
John M0VAZ
Post #629047 5th Jun 2017 9:20am
