![]() | Home > Puma (Tdci) > LR Recalls and Technical Bulletins |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1262 ![]() ![]() |
Try starting here -
https://www.gov.uk/check-if-a-vehicle-has-been-recalled |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
That's a good start. Thanks.
I'm sure I've seen mentioned other 'problems ' regarding oil pumps and routing of pipelines etc that are not mentioned there!! Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
Outstanding recalls should show up as an advisory on the MOT. Or any Dealer can tell you if there are any outstanding.
TSB's are different, they're not compulsory they just highlight common issues that have been identified along with solutions. They're chargable repairs if you're outside of warranty, you can only really tell if they;ve been done by looking at the car along with the TSB. |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
Hi there, you can log on to https://topix.landrover.jlrext.com/topix/vehicle/lookupForm and input your own Defenders details, to access all information on any outstanding issues and also previous work already carried out, though there wil be a charge for the service.
Alternatively you can just check with your local main dealer. |
