Home > Puma (Tdci) > Inlet air temperature sensor
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
I am getting fault code P0113 intake air temperature sensor circuit high input
And if I read the snap shot data for this fault I get an incar temperature and outside temperature of 215 deg C
When I remove the loom connector from the sensor (I presume it is the one on top of the air box) should it than normally read 0? (I get the same code and same temp value) or is this sensor situated someware else?
Live data (removed/connected) -40 deg C
Regards. Q
Post #628054 31st May 2017 9:30pm
TopQ1967
It was a lose connector on the LH of the gearbox.
This problem solved now Smile
Post #628166 1st Jun 2017 1:00pm
dorsetsmith
Deja vu
Post #628249 1st Jun 2017 6:37pm
