![]() | Home > My Defender > Josh_WA's Defender 110 Double Cab |
Josh_WA Member Since: 24 Aug 2010 Location: Perth, W.A. Posts: 9 ![]() ![]() ![]() |
My VW "99" relay for the variable intermittent wipers arrived today so I installed that. it was pretty easy really, just unscrew the dash and then find the wiper relay by turning the wipers on and seeing which one clicks.... once i found it i yanked it out and replaced it with the "99" relay then screwed up the dash again.
It works a treat and is so much better to have either one wipe when you just quickly press the wash button for a quick clean or 3 wipes when you want a bit better clean by touching the wash button a bit longer. ( previously it was 5 wipes whenever you pushed the button no matter what). the variable intermittent is pretty cool also and better than standard. Pretty good mod for $15 ![]() Anyway here are some pics. Relay ready to be installed ![]() This is the relay that needs to be swapped out.... second from the right next to the flasher relay. ![]() 99 relay installed ready to put instrument cluster back on ![]() Josh 2006 Defender 110 Double Cab |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Nice truck Josh
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
Unfortunately i did not import this one it was imported about 12 months before i bought it... ________________________ Josh 2006 Defender 110 Double Cab |
nzdefender Member Since: 30 Jun 2011 Location: NZ Posts: 6 ![]() |
looks great w/ the top off! Trying to decide on which model Defender to pick up for myself.
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 ![]() ![]() ![]() |
She's a beauty! Same truck as mine and colour etc. But yours looks better with the huge tyres and the red Aussie dirt on them!
Enjoy! ![]() |
4d47 Member Since: 19 May 2011 Location: Albany W.A Posts: 2 ![]() ![]() |
Cheers for that, It's an awsome looking truck surprising the doudle cabs are only just really getting popular.
