Home > Maintenance & Modifications > Front wheel bearing seal
xcentric
On my Defender 110, the front left ball joint seal doesn't seem to be sealing at all now as there's a think layer of grey goo all around the ball swivel.
I know there are various posts on how to do it, but it seems quite time consuming - is it? Not got a garage so it would have to be done my my gravel drive.
Alternatively, how much would it cost (roughly) for a garage to do it?
thanks!
Post #623128 10th May 2017 1:22pm
It rather depends which seal you actually mean, since your title refers to a wheel bearing seal and your post refers to a ball joint seal, whereas I suspect that you actually mean the swivel housing seal, i.e., the very large one on the back of the swivel housing.
If you do mean the swivel housing seal, the scope of work is rather depndent upon the reason it has failed.
If it really is just a knackered seal and the seal is the only part that needs chaging, then there is a quick and easy way. This involves releasing the retaining ring for the old seal and cutting the old seal to remove it, then carfully cutting the new seal so that it can be fitted over the axle tube end, positioning the cut right at the top with sealant, and refitting. This saves stripping out the hub and swivel etc.
If however the reason for the failure is worn swivel pins (which is quite likely) then there are not really any shortcuts and it becomes a bigger job (remove wheel, remove drive flange, remove and tie up the caliper, free off the old seal, remove swivel pins and lift swivel pin housing complete with axle, and hub off. pull out halfshfat, then remove swivel housing. Then clean uplocate new seal over the swivel housing, refit housing to axle, fir new swivel pin outer bearing races, replace halfshaft, replace swivel pin housing complete with axle and hub, fit new swivel pins, shimming the pins for correct preload, then refit everything else and fill with one-shot, job done).
If paying for this, expect to pay for about 2 man hours labour plus about £250 in genuine parts per side, I would think.
Post #623142 10th May 2017 2:05pm
xcentric
yes I do mean swivel housing seal - thanks for the clarification. Is there a way to tell if the swivel pins are worn? Car has done <30k miles, but has had a tough life for a lot of them (Camel trophy).....
Post #623145 10th May 2017 2:12pm
Easiest way is (1) enlist the help of an assistant, (2) jack the front wheel off the ground, (3) with the assistant pressing the brake pedal firmly, use a bar under the tyre to check for up/down movement of the wheel. If present, the swivels need attention.
The assistant on the brake pedal should eliminate any play in the wheel bearings by locking the brake disk in the caliper.
Generally play in the wheelbearings will be felt by rocking the wheel and will be present both up/down and side to side. Play in the swivels will be up/down only, but it usually requires more force to find since the mass of parts moving is much greater than is the case for wheelbearings.
Worn or sloppy swivel pins also make it more likely that you'll experience shimmying from the front wheels, giving an effect on the steering similar to monstrously out-of-balance front wheels. Quite unpleasant, really.
Post #623154 10th May 2017 3:44pm
xcentric
ok thanks.
Driving, it's actually the best-steering Defender I've tried - relatively precise to place and with no weaving or wobble at all. So it seems to suggest that the pins are probably ok, but will check as you suggest.
Post #623158 10th May 2017 4:05pm
