![]() | Home > For Sale & Wanted > [For Sale] Range Rover 6x6 Fire tender |
LiftedDisco Member Since: 17 Aug 2014 Location: Towcester Posts: 355 ![]() ![]() |
If your mate wants to send me an e-mail, I'll pass the information on to Brooklands as I do quite a bit with them.
I believe that they already have a Carmichael fire tender but it needs a lot of work. My work e-mail addy is Robert.alvarez [at] deboer.com No promises, but just might be of interest... |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1661 ![]() ![]() |
its still in use but looking a little tired
the new one is running in 4x4 low and scrubs its tyres heavily when tuning sat very low on the rear also built by Carmichael ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Carmichael TACR2 (tactical Air Crash Rescue mk2 if I remember correctly)
Built as 6x4, some converted after demob to 6x6 for civilian use 900 litres pre mix foam (very corrosive) in grp tank mid mounted single pressure Godiva pump off pto both rear axles should have an additional second coil spring inside the std rear coils very few special parts on the chassis - brake master cylinder I think is a special |
Whoever buys it should be pointed here.....
http://thesixappealwheelgroup.org/ ![]() |
