![]() | Home > Maintenance & Modifications > electrical woes |
countdecash Member Since: 14 Mar 2016 Location: dublin Posts: 24 ![]() ![]() ![]() |
its a 99 td5 90
![]() Click image to enlarge brake and reversing lamps have switch feed and fused and feed from ignition switch ![]() you need check for short cct in brake and reversing lamp cct see wiring digram as the same fuse is used both As to your Battery flatting problem |
Thanks for the reply and diagram. They dont come on with key out or ignition off but i presume there's a short somewhere. I'll get it checked out
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
As well as the brake and reversing lights, the same circuit supplies the alternator and speed sensor.
Green/Yellow wire circuit goes from Fuse 6 in the facia fuse box, to header C0292 - ![]() Click image to enlarge ![]() Click image to enlarge From C0292, it goes to header C0294 - ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
beat me too it
