![]() | Home > Maintenance & Modifications > Which headlight wireing upgrade. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Land Reziger with or without ceramic connectors is fine, fit and forget. I'm my case I just added a little colour coding which suited me. I also changed to Durite Relays with diode. Again you don't have to.
If you have incandescent bulbs as headlights I'd tend to go for ceramic, but not a necessity. If you have or want LED's as I now have plastic connectors are fine. I'm not overly keen on the quality of the Boomslang looms. You can of course make your own loom if you wanted, but not all of us have the time or inclination to do so. 👍🏻 ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Boomslang looms are OK, but you can buy almost identical ones as Boomslang off eBay for a fiver . The only difference is the red live feed wire is slightly shorter, however if you are taking the feed from the alternator that does not matter if from the battery then just join an extra length to the feed wire.
I have bought Boomslang and the eBay ones and the relays are the same, though I would always recommend swapping the relays for a good quality make. As Custom90steve has said Land Reziger are the best in fact I would go as far as saying they are like OEM quality. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I do have the Land Reziger twin relay and mounting screw brand new unused if anyone wants it. Surplus to use to me. If anyone wanted to make their own or wanted a twin relay system ____\We|Will|Win/___
How much do you want for them
![]() http://www.youtube.com/user/conwy1 |
None of those two.
![]() Land Reziger or Land Rieziger just do not exist. It is Landreiziger, which actually means Overlander. Some people on here do not like it when I call Nakatanenga just Naka as a short. At least I will never call them anything like Nakalaningla or so. ![]() I did click the Land "thing" in the poll, have it for years, works perfect, and even my dealer commented that it is a first class piece of kit. ![]() Below is link to the def2 original long much commented Landreiziger thread. I still have to hear the first negative comment about this loom, but I think to have seen several of the problems listed by the OP mentioned in other threads about the Boomslang loom. Eric http://www.defender2.net/forum/topic26097....ziger+loom You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Its a British thing we love to split foreign language words and to hyphenate, particularly when they are fronted by English words . ![]() http://www.youtube.com/user/conwy1 |
I'm using a phone, can't be bothered to manually type out the words spell check doesn't recognise. I'm 99.99% sure everyone knows knows exactly what we mean. ____\We|Will|Win/___
Gilarion, Oh I see. So you mean I should be writing Naka Ta Ninja.
![]() Custom Steeve, sorry to see you take it a bit personal. I'm off now, going to watch French TV election show now and (hopefully, but probably yes) enjoy the results of their elections. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I am sure I watched that film in the eighties did not Bruce Lee star in it. ![]() http://www.youtube.com/user/conwy1 |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Well after reading another post about headlight failure I thought that I should get a loom ordered as the light switch has been in service since 2008. I have ordered the Landreiziger with the ceramic connectors. I just have to sort out a translator when the site switches from Edge to IE. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Can I ask why you changed the relays and which one's did you change them to. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
I fitted the boomslang loom on mine from paddocks.
I would say it was only OK quality, came with ceramic fittings but I had to re-crimp all the connectors after a wire fell off when taking it out of the box! |
