Home > Puma (Tdci) > Rust on random bits |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 |
its a defender
Rust is covered under warranty, just get your dealer to have it replaced. '08 LR Defender 110 '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
7th Feb 2011 5:57am |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
they would replace the turbo and manifold for surface rust?
What is the other thing? |
7th Feb 2011 6:29am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
off at a tanget here....your engine lifting point is red ?
not sure I've noticed one of these in red before? and re; the rust I think you might struggle to get them replaced - albeit it looks naff and they should (mind you for the few pennies you think they'd do it right in the first place!) - good luck. |
7th Feb 2011 8:55am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Every hot side of every turbo in the world will rust.. cast iron and salty damp air dont mix.. as for getting it replaced don't even try! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
7th Feb 2011 10:56am |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
Dont think I've had a Defender where those bits haven't grown rust, although picture two looks a bit more extreme.
I wouldn't be worried about rust there. |
7th Feb 2011 1:52pm |
Please, please, please............. NO ALLARM!!!!!
Turbo housing, common rail main collector and engine block are made on cast iron!!!!! ALL engine maker do it in cast iron!!! (or in alloy, but cast iron block are more stronger) ALL exhaust manifold (turbo housing is a part of) are made in cast iron (or stainless steel in same bike and ultrasport car) and it taken "rust color" but it is only a color!!!! Cast iron is like stainless steel, it produce an surface oxidation (brown color on cast iron) but IT ISN'T RUST CORROSION!!!! In the past same engine maker painted the cast iron engine block, but now, for costs cutting reasons nobody do it!!! look the engine block of a Discovery 4 new!!!! the same BUT IT ISN'T RUST CORROSION!!!!! So if you go to the Dealer........ you only make an ugly "figure"............... You can cover or remove the rust on the common rail collector (only for cosmetics reasons) by OWATROL or similar rust inhibitor fluids....................... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2011 2:09pm |
what is a common rail collector and thanks for the info
7th Feb 2011 4:24pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Middle picture Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 4:25pm |
The "rusty" collectors where start the small metal pipes to the injectors, middle pictures like "willy eckerslike" said.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2011 6:47pm |
I assume that thing rusting is normal as well?
7th Feb 2011 7:33pm |
YES!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2011 7:48pm |
Dgardel you are the veritable 'Master of the Rust' Couldn't say Rustmaster due to copyrights! Probably! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Feb 2011 8:27pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
If you really don't like it then wire wool and High Temp: Engine/Manifold paint will restore the factory look. Won't make any overall difference however and it will come back as the paint will eventually burn off.
7th Feb 2011 8:31pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Why hasnt someone mentioned search
But yes its very normal!! Mike |
7th Feb 2011 9:14pm |
