Home > Puma (Tdci) > which battery to go for?
Page 2 of 2 <12
bear100
Well bought the CTEK charger and done the regen mode and it's better than its ever been Shocked seems to have loads of power when turning the engine over! Nice bit of kit Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #625244 18th May 2017 9:53pm
StuLandy
2008 Defender 110 Puma 2.4 CSW Alpine White
My Batteries laboring a little now after 10 years, anything different to get other than whats been suggested?
Stu
Post #667085 26th Nov 2017 7:44pm
mees
Netherlands 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Merry Chrismas everybody
Which battery should I take? Cannot decide between below 3 options.
Varta LFD90 (90ah)
varta blue dynamic G3 (95ah)
Varta silver dynamic H3 (100ah)
Car is used occasionally but always on Ctek charger when not used
Post #673324 25th Dec 2017 3:39pm
ericvv
You can't go wrong with any of those three. When my factory Varta battery was past its best after almost 9 years, dealer replaced it by the same which essentially is a LFD90. The blue dynamic you mention is not much different, also a wet cell battery, but the silver dynamic is a AGM battery. More expensive, and for normal use not really required. But you can't go wrong with any of those three.
Dus gooi een muntje op zou ik zeggen. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #673331 25th Dec 2017 4:21pm
mees
Bedankt Eric Laughing
Post #673370 25th Dec 2017 10:28pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
VARTA Professional Dual Purpose AGM L95 - 840 095 085
https://www.varta-automotive.com/en-gb/pro...40-095-085
- 95Ah
- 850 A
- Width : 175 mm
- Length : 353 mm
- Height : 190 mm
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #673383 26th Dec 2017 12:34am
Zim
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
gilarion wrote:
No matter which battery you have invest in a CTEK charger with a battery reconditioning mode and every two years or sooner use that mode and you will get the maximum life out of your battery.
I have even rescued dead batteries with the CTEK battery reconditioning mode.
http://speed.academy/how-to-maintain-car-batteries-ctek/
Ditto on the CTEK charger - my Landie is only used circa once every ten days - I started having issues with the battery running down until I bought one of these. Depending on the charger you get, you get different couplings, one you can permanently wire up to your battery which has a connector - this connector plugs into the corresponding connector on the charger wire. It saves you on having to take the seat apart every time you want to get the charger on! 2007 Defender 90 XS
2022 Defender D300 HSE X-Dynamic
Post #675637 4th Jan 2018 9:55am
Page 2 of 2 <12
