![]() | Home > Maintenance & Modifications > 300Tdi Defender 110 2" lift brake hose |
l3n0x Member Since: 03 May 2017 Location: Budapest Posts: 26 ![]() ![]() ![]() |
Hi!
Just ordered a Terrafirma 2" kit for my old lady, but forgot to add extended brake hoses. Can I get away with the stock brake hoses & lift for a while, or do I seriously need the longer hoses right away? If so, is there any cheaper option than the TF602L? Thanks! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8347 ![]() ![]() ![]() |
if your on tarmac they will be fine stock for a while its only on full flex at full lock you normally need longer.
fit the lift and with it level turn to full lock see if it puts strain on the current pipe. Brake pipes you would be just as well to buy custom made ones from llama4x4 - ring dave, you can also get ones that go straight to a banjo fitting (45deg) for the front caliper. do away with the extra join on the top and makes maint of hubs easier. http://www.llama4x4.com/ no link to llama other than used them for last 10 years, great pipes, great service, never had one fail. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
