Home > For Sale & Wanted > [Wanted] 110 DOUBLE CAB ROOF AND SIDES
ami1971
need to do a conversion on a 110 - any one have roof and sides please?
Post #619937 27th Apr 2017 3:57pm
A 110 double cab doesn't have sides! Do you mean the rear panel for the cab?
Don't forget you'll also need a rear tub with the correct lower bulkhead.
Double cab roofs are the same on 110 and 130 but are quite hard to come by and tend to be expensive. The cab rear is the same as that used on a (single cab) truck cab and should be quite easy. The rear tub is unique to the 110 DC and again is scarce and expensive.
Good luck with your search.
Post #619942 27th Apr 2017 4:07pm
Lancerdoc999
I have a friend who is selling a roof, rear panel, internals and rear hood and sticks.
Post #620034 27th Apr 2017 11:35pm
