![]() | Home > Maintenance & Modifications > Tuning |
| Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487
Evening Peeps
Has anyone had any experience on a PSI Power Upgrade Chip? Life is one big adventure, that's why we have the vehicle for the journey. |
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610
Yes, loads! lol
Contact West Somerset Land Rovers, in Wellington (01823 674561), and ask Richard Willis about safe methods of tuning. He'll guide you down the right path, and sort you a Forum Discount at the same time! Regards, Gary. |
Thanks Gary, I've got the chance to buy one at the minute with2 chips supplied but not sure if it's a gimmick or not? Life is one big adventure, that's why we have the vehicle for the journey.
These things are an extremely crude way of making your engine produce more power, as they try to fool your engine. There are many parameters within the software that should be changed to make a nicely balanced state of tune, which these external boxes can never access.
There is no plug in tuning box that can compare with a properly made remap. If you're going to do it, do it properly or not at all. |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
yes, go to bell auto services or IRB for proper remap.
LOL Handbags out eh? Let's not go there. |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
That is a bit out of order isn't it? Slagging off the competition for no reason. Doesn't seem very professional http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I'm not slagging anyone off. I apologise if it came across like that. Pete is the brains behind all IRB's remaps, Fact. I thought this was common knowledge?
Both are freinds of mine. |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
If you can handle the flat spots |
I wasn't aware of that bit of common knowledge http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS Last edited by JSG on 9th Feb 2011 12:02am. Edited 1 time in total |
not if you carry on like that! Ians a good kid, doesn't make his money from remaps. Pete has a great reputation but you all do the same tricks, no one has crack the ecu's code from what i have seen. smoke and mirrors Was just giving people options apart from YOU, and once again your professionalism fails you |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Hi i experienced flat spot with my BAS tune and a few other guys have.....and basically they just turn the power down to overcome this ? the tune is good but as said i and others have experienced these flat spots resulting in me sending the tune back.....I can't recall where i had the flat spots it was a while ago i had the tune...if you look in the search and put in Flat spots you will find what your looking for
Have a read of this you will have to just scroll down and read a few post....BIGFOG...szracer. http://www.defender2.net/forum/topic4681.h...p;start=15 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Cheers fekete
read the post and feel mine would benefit from the BAS remap as it is a bog standard Landy. Also like the option of having the EGR closed permanently, and being able to put the original tune back on the car any time I need too. Still it was good to read about both sides of having a remap done, both the happy ones and the not so happy. |
