Home > Maintenance & Modifications > Painting galvanised steel
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Apologies if this has been discussed before but I've done a search and can't quite find the answer.
Can anyone give advice on painting galvanised steel?
Fancy giving a galvanised steering guard a bit of a funky paint job
Thanks in advance for your advice Very Happy The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #618851 23rd Apr 2017 11:20am
sako243
I would say degreaser then I'm pretty sure there are etch primers designed for galvanised stuff. Then choice of paint.
BTW recently tried Paint Man's prep cleaner, that is some great stuff for degreasing and particularly getting rid of glue etc from inside doors. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #618866 23rd Apr 2017 1:04pm
Key galvanised surface, panel wipe, etch prime, hi build primer, dry sand 600 grit, panel wipe, base coat, clear coat after around 14 - 22 hrs after base. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #618871 23rd Apr 2017 1:44pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I've just done my galv chassis etc on my build thread, start off with checking for any extra galv deposits etc filing down as needed, then t-wash it all ( this is effectively an acid wash and speeds up the natural oxidisation of the galv), next is an etch primer this needs 3/4days to work properly before being painted over.
I have done a mini guide of sorts as part of my thread just trawl through Maggie's link below Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #618884 23rd Apr 2017 3:16pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Agree with the above, make sure you let the etch primer 'bite' before putting anymore coatings on. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #618891 23rd Apr 2017 4:23pm
It is indeed a time consuming and labour intensive thing.
This is what many don't understand as to why paint shops cost so much.
Even the paint its self, especially metallics are costly. ____\We|Will|Win/___
Post #618902 23rd Apr 2017 5:43pm
zsd-puma
Exactly, i love it when you see someone who's scraped the side of their car and decided that he body shop wanted too much and that they could do just as good a job themselves with rattle cans to respray the entire rear quarter of their car. Laughing
Post #618930 23rd Apr 2017 7:34pm
Rallymental
Thanks all very much for the advice, any thoughts on type of top coat paint or is it more important to get the base right? The definition of insanity is doing the same thing over and over again but expecting different results.
Post #619017 24th Apr 2017 12:32am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I want to get some new mudflap brackets, they come galvanised and would like to get them powder coated black.
Can galvanised parts be powdercoated ok? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #619028 24th Apr 2017 7:44am
Yes, yes you can powder coat glav no problem.
R.e. The base coat, that is the colour coat.
So do you mean the clear lacquer, the final finish?
Normally have around 2-3 coats of base, and similar for the clear coat. ____\We|Will|Win/___
Post #619133 24th Apr 2017 3:09pm
meeerrrk
great news, i'll get some ordered...thanks! My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #619135 24th Apr 2017 3:32pm
