![]() | Home > Maintenance & Modifications > One shot swivel grease when to top up? |
Retrostu Member Since: 03 Feb 2016 Location: Kent (AKA Garden of England) Posts: 128 ![]() ![]() ![]() |
Hopefully not a silly question but I last topped my 2005 TD5 90 swivel grease up in my swivel housing was a year ago as I noticed the ball was looking quite dull & grey, however now I have purchased my beloved landy back and no maintenance has been done (only cover 3k since I sold it) is it worth filling up again with one shot grease?.
I used to normally see a build of greasey crud around the ball but wondered if it does lose a little in time although I have never seen any on my drive or splattered underneath it either. So Should they be shiny or a graphite grey colour normally?. It's more important to concentrate on what's ahead of you than what you have left behind. This is what I keep watching to remind me why I own/keep my Defender. https://youtu.be/x4DZgOcgn1s |
Anyone? It's more important to concentrate on what's ahead of you than what you have left behind.
remover filler plug check the level
Thanks all for your help will make a dipstick up and check the level. It's more important to concentrate on what's ahead of you than what you have left behind.
Well made up a make shift dipstick and it measured 2 inches in level in both sides so is this enough?. It's more important to concentrate on what's ahead of you than what you have left behind.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
the older oil filled used to be up to the top of the filler plug, so I can't see why the thicker grease should be any different.
I'd fill both sides up to the top if it were me. |
