Home > Maintenance & Modifications > MOT (A boring question!)
I'm aware that with Tow socket covers I believe or similar things if present a tester is not allowed to remove it.
Is this correct still?
What does this apply to?
Would it also include a spotlight covers also?
I don't think the spare wheel is included in an MOT anyway but I have a cover on that too.
I'm just interested to know about the Tow socket and spotlight covers mainly.
I think if there is a cover present it cannot be removed across the board but could be wrong.
Obviously no covers ever allowed on obligatory lights for obvious reasons. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #617090 15th Apr 2017 10:20pm
Matt90
United Kingdom 1990 Defender 90 2.5 TD HT Bronze Green
My 90 sailed thought its last mot with no advisories 😗🎶
Post #617092 15th Apr 2017 10:24pm
Rolling with laughter ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #617111 16th Apr 2017 12:05am
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Not sure about lights but spare wheels are definitely tested if present. They're one of those weird ones; you don't have to have one but if you have it has to work.
I guess the same could be true of extra lights etc. The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #617112 16th Apr 2017 12:18am
mk1collector
Mine had its mot last week and if the tester didn't know me it would have failed..... The reason being, I had given him the spare set of keys with no fuel cap key and apparently they have to check the fuel cap seal integrity Rolling Eyes Ray
My build thread
Post #617119 16th Apr 2017 12:42am
landroverdiver
I have the standard lockable fuel cap and every MOT has an advisory that the temporary cap has to be replaced!
Post #617146 16th Apr 2017 7:42am
zsd-puma
Quote:
not sure about lights but spare wheels are definitely tested if present
Not true, it's not a testable item. If a tester happens to notice that it's cracked and falling to bits they can give you an advisory for it, but it has never been a reason for failure.
Point 4.1 of the MOT inspection manual;
Quote:
This inspection applies to tyres fitted to the road wheels only. The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel
Given that Defender wheels are usually hung on the back door and very visible they're easily noticed.
That's not true either.
Section 1.9 MOT Manual
Quote:
Some tow bar electrical sockets are ‘hidden’ behind an access panel in the bumper or bodywork. Unless requiring the use of tools or specialist equipment, these panels must be removed to facilitate the inspection of the towbar socket
So a push on rubber cover isn't going to stop them looking.
Spotlights don't have to work in the MOT. However they are supposed to go out when the headlamps are dipped or have covers fitted to them if they don't(which effectively means they're no longer lamps). Other than that unless they have dangerously exposed edges or perhaps liable to fall off the vehicle they're not a fail.
Almost. Clear plastic covers are ok, like the clear headlamp protectors Land Rover sell.
Usually in the manual it specifically says if a tester should remove a cover from an item to test it. Basically it's common sense. If it's just a push on cover like a trailer socket cover it'll say remove it if present. But they're not allowed to go dismantling half the car.
It's all here;
https://www.mot-testing.service.gov.uk/doc...000101.htm
Post #617152 16th Apr 2017 8:20am
zsd-puma
Because the tester is an idiot.
Not quite. It wouldn't have "failed" per se, but he could have refused to test it. The difference being if it failed they'd have charged you and issued you with a failure. However a refusal to test isn't chargable and they have to refund you if you've paid.
Quote:
If any of the following reasons apply, the test should not be carried out, the vehicle presenter informed and any fee paid for the test must be returned. It is therefore advised that ‘refusal’ items are checked before starting the test.....
.....g. A proper examination cannot be carried out because any door, tailgate, boot, engine cover, fuel cap or other device designed to be readily opened cannot be readily opened.
Post #617155 16th Apr 2017 8:28am
Some of it really does go beyond sensible conclusion lately I do admit. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #617192 16th Apr 2017 10:53am
zsd-puma
My favourite is the "arse covering" advisories you get. like "covers fitted to engine bay, preventing inspection", which pretty much all modern cars have fitted from the factory these days.
So if the battery turns out to be insecure, the tester can't be blamed for passing it because it had two screws holding a cover on. Laughing
Post #617217 16th Apr 2017 1:11pm
