Home > Maintenance & Modifications > Mobile Mechanic? Staffordshire/Shropshire/Cheshire area?
Jim_Bean
Hi guys,
Do you know of a good mobile mechanic? I am struggling to get the small turbo hose replacement back on to my 2.2 Puma.
Having taken the old rubber hose off and part fitted a new silicon hose the vehicle is not now movable and i cant get it to a garage.
Any ideas of who I could contact?
Post #616871 14th Apr 2017 9:40pm
geobloke
Or perhaps a kind soul off the forum. Whereabouts on the border are you Jim?
Post #616875 14th Apr 2017 9:54pm
Jim_Bean
I'm in Loggerheads - near Market Drayton.
Post #616883 14th Apr 2017 10:16pm
Jim_Bean
The other two hoses fitted but cannot get the smallest one seated. My hands are too big!
Post #616884 14th Apr 2017 10:16pm
Jim_Bean
The OEM rubber hose has failed and I'm trying to fit the BAS silicon hose. Its already a really tight fit and I simply cant get it seated.
The Defender is dead in the water. I cant now get the hose on OR off.
Post #616886 14th Apr 2017 10:22pm
excossack
Could you warm the hose up before fitting to make it more pliable? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #616924 15th Apr 2017 9:07am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Thinking the same. Blast it with a hair dryer on hot - should soften and enable you to remove. I usually drop hoses in hot water before fitting. Both softens and lubricates.
Post #616935 15th Apr 2017 10:16am
excossack
Maybe a thin smear of oil around the inside of the tube/pipe to aid insertion? 1999 Defender TD5 110
Regards
John M0VAZ
Post #616941 15th Apr 2017 10:26am
Jim_Bean
I'll try to blast it with a hairdryer and see if that allows me to move it.
Then heat it up in hot water before trying to install it?
Post #616953 15th Apr 2017 11:17am
geobloke
Hi Jim have you got it sorted yet??
Post #617037 15th Apr 2017 7:09pm
Jim_Bean
Nope. I have reduced my knuckles to a red mess but otherwise no progress.
I can't get the hose back off to heat it in water. I did try a hairdryer and was able to move it slightly but nowhere near enough.
Post #617038 15th Apr 2017 7:12pm
geobloke
Can you get hold of some silicone lubricant or even rapeseed oil would do just to get things lubricated enoug to easily twist and slide?!
Post #617039 15th Apr 2017 7:13pm
Jim_Bean
I tried lots and lots of GT 85. The main problem is that there is no space to pull the hose.
I think it'll have to go to its favourite position here....
Then try and get it up to Pete Bell. Picked a terrible time as we're supposed to be taking the kids on holiday.
Joys of Defender ownership!
Post #617041 15th Apr 2017 7:19pm
geobloke
Well at least GT85 smells pretty good Rolling Eyes daft suggestion... How about one of the kids? If they are old enough of course.
Aren't NWS Land Rover pretty darned close to you? Market Drayton way. Would they pop out?
Post #617044 15th Apr 2017 7:35pm
Jim_Bean
Not used NWS before. Any good? Would you recommend them? I think i've been past them on the way to Whitchurch.
Post #617047 15th Apr 2017 7:53pm
