Home > 130 > Intank fuel pump
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Intank fuel pump
Anyone had already trouble with his in tank electric fuel pump (2.2 Puma)?
Seems mine stopped working completely
Post #615980 11th Apr 2017 10:15am
CaptainDan
Australia 2013 Defender 130 Puma 2.2 HCPU Alaska White
Hi have you sorted the problem out, I have a 2.2 and have had a few problems from new but not with the electric fuel pump, would be interested in what you found out.
Post #621583 4th May 2017 10:55am
TopQ1967
Hi,
No time recent months. A new electric pump is on the bench.
Now what is best?
Lower the tank, or lift the tub?
Lowering the tank, makes me afraid to damage the fuel lines.
Advice appreciated!
Post #625331 19th May 2017 11:19am
davew
Cut a hole in the floor, change the pump, put a removable plate over the hole. Some people rivet the plate down and drill out the rivets when they need access, I use rivnuts and bolt it down. That way access to the pump/sender/pipes will never be an issue again. Oddly Land Rover did this for the Discovery and Range Rover but never did it for the Defender which, on a 90 at least, has the hardest tank to drop out. On a 90 you can cut the floor between the bracing bars.
When I cut the hole in mine I managed to feed a sheet of 3mm steel up between the tank and the floor first to prevent any accidents while cutting through. http://www.yorkshireoffroadclub.net/
Post #625340 19th May 2017 11:46am
TopQ1967
Good Idea. Saw this option on earlier models too.
Think it is the easiest way to do the trick.
Regards
Q.
Post #625348 19th May 2017 11:54am
TopQ1967
I didn't want to cut the floor. Tried to remove the tank, but broke the fuel line outlets in doing so. Sad
And the worst part... it was not the problem!
Post #626042 22nd May 2017 2:11pm
