Home > Maintenance & Modifications > Anybody using one of these?
Ayrshirelandy
I am thinking about a visible deterrent as I have several professionally fitted ones and thought of one of thesehttps://www.amazon.co.uk/POSSBAY-Univ...&psc=1 I did try an Autolock which left small pinch marks and so went back. Just feel if you have a visible deterrent it helps. Any thoughts? 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
Post #615680 9th Apr 2017 10:45pm
Will it fit a Defender? It looks to me as though the prong will foul the dash or screen.
Given that it takes about 1 minute to remove the wheel, or cut the wheel and slip off the device, is it effective?
If it makes the next Defender an easier target than yours it can't be bad, but I feel that there are more effective solutions such as pedal locks.
Post #615693 9th Apr 2017 11:16pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
This looks exactly the same (but cheaper) ... and many reviews mention pinch marks on the wheel
https://www.amazon.co.uk/UNIVERSAL-HEAVY-S...SHVEFQ0SJ7
also another clone with more reviews... https://www.amazon.co.uk/ANTI-THEFT-SECURI...2QT5QK0RKC
Post #615699 9th Apr 2017 11:54pm
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Bright yellow Disklok and pedal locks for me.
Very visible.
Post #615720 10th Apr 2017 8:06am
zsd-puma
I've got a Stoplock Pro, it's TH3 approved unlike their cheaper ones, only the disclok and stoplock pro are Thatcham approved.
Yes you can probably remove the wheel with it fitted, but it makes it a little more awkward for them, and they need to carry a spare steering wheel.
The disclok is probably the most effective, but then again it's massive and more awkward to carry around/fit each time. I went for the stoplock as it's easy to pop on quickly when going into the shop. I think with the disclock the novelty would wear off and i'd get lazy - a steering lock is pretty in effective if its not fitted.
Post #615734 10th Apr 2017 10:01am
