Home > V8 > 98 3.5 V8 110 pickup..cant start after 6 years
Mystique
Wales 1998 Defender 110 V8 Petrol PU Fuji White
hello...everybody
pretty a newbie here..
i cant seem to find a solution to this
tried to start my landy after parking for 6 years and it wont start
the following replaced:
New dizzy,spark plugs ánd HT cables
new battery 12V N70 Ah
new fuel pump (Facet)
cleaned rocker assembly...was pretty dirty
timig lined up by the book
...with all this it turns,with very weak compression at the cabs.......i cant seem to get it running
plizzz Help....
what could be thproblem.. Embarassed
is it a cylinder head job Big Cry
Post #614251 3rd Apr 2017 4:36pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
If it's been standing it may have some valves stuck?
Take the rocker covers off and turn it over watching the valves go up and down.
I take it you have a good spark at the plugs? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #614256 3rd Apr 2017 5:03pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I would also try flushing all the old fuel out and just use brand new stuff.
Did you change the oil too?
Have you checked the spark with the plugs out of the head?
Have you tested the injectors or is it a carb?
Is it firing at all or just just turning over?
Post #614257 3rd Apr 2017 5:09pm
ian series 1
Also if it's on carbs, worth checking float needles are not stuck?
They don't like standing for that long, worth giving them a good strip down and clean out. Thumbs Up 80" 80" 86" 88" 90"
Post #614260 3rd Apr 2017 5:20pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I just injected some fresh fuel into the carbs and crank it over, a small syringe is good for that. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #614282 3rd Apr 2017 6:50pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Are you 100% sure you have the leads on the cap correctly...............?
Post #614316 3rd Apr 2017 8:27pm
Mystique
thnx for the quick response...
yeah...old fuel flushed infact i took down the gas tank to make sure it all out
i gat a fat spark at the plugs
its not firing at all...
im from cranking it now with gas through the carbs.....oh boy now the starter is just turning with a loud noise...could be the Bendix i think....
im now stuck could it be iv crancked it too much valves are bend. or its just the starter this time?????? Crying or Very sad Question Question Question
Post #614388 4th Apr 2017 7:55am
Mystique
en cleaned up the carbs.. needles...well i doont remember
Post #614389 4th Apr 2017 7:57am
