Headlamp Bowls
I recently fitted a Land Reiziger loom.. Great piece of kit but I noticed I don't have any headlight bowls... should I have them?.. Do I need them? I am awaiting the arrival of some wipac crystals to replace my cheap and not very cheerful lights so I could hopefully install some then if needs be
Thanks
Julia
7th Mar 2017 7:31pm
Retroanaconda
Yes you do, you just have the open backed ones. These are handier as you can change the bulb or connector/wiring without removing the headlamp, which requires removing both the sidelight and the indicator also.
7th Mar 2017 7:39pm
Profyaffle
Thanks Retroanaconda.. I wondered as i'd seen other posts with 'full' headlight bowls fitted.
