Home > Td5 > Clunk when change gear
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Hi, My 90 td5 has a annoying clunk when change gear, no matter how slow and smooth you make the change. New halfshafts and flanges. Ujs ok.Any ideas? Also when selecting 1st or reverse its erxtremley noticeable feels like you have been hit up the rear ? Front diff oil grey after only 4 months ??
Any help apprictated
Alex
Post #606810 5th Mar 2017 1:13am
4RF RDS
Clunk probably your DMF and the grey fluid in the front pumpkin is from your swivel balls. Get the inner seals replaced or remove altogether and fill with 90 weight oil instead. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #606813 5th Mar 2017 2:38am
Alextd5
Thanks. Swivel grease is what I thought. Dual mass flywheel has just been replaced with a valeo kit.
Post #606814 5th Mar 2017 2:41am
4RF RDS
Other driveline clonk can be the upper "A" arm ball joint above the rear axle Check it for play and, wear. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #606815 5th Mar 2017 2:53am
LR90XS2011
what 4RF said Thumbs Up DEFENDER 90 TDCI XS,
Post #606822 5th Mar 2017 8:48am
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Also check the UJ's on both prop shafts
Post #607325 6th Mar 2017 9:15pm
