Home > Technical > Clutch adjust MC pushrod
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Clutch pedal height adjusted, Pushrod giving me fits.
My pushrod has 2 nuts above where it enters top of pedal and a locknut below.
I cannot get the 2 nuts undone, which I need to in order to adjust to the 1.5mm free play. There is no space for an open end spanner to grab the nut closest to top of pedal assembly.
Is there a trick before I go buy a grinder to shave up a spanner to fit in there?
200Tdi, and I am following the manual.
Assistance appreciated. 2013 110 - Keswick Green
1995 ExRAF 110 Utility
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #606354 3rd Mar 2017 11:50am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
You need to grind the shoulders of a couple of spanners to do this any sense! Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #606402 3rd Mar 2017 2:08pm
Mo Murphy
There is usually enough slop in pedal pivot to cover the free play.
50 Shades of Pennine Grey
Post #606608 4th Mar 2017 11:13am
