Home > Maintenance & Modifications > Dim Dip Resistor
molecatcher
United Kingdom 2004 Defender 90 Td5 HT Auto Arles Blue
Dim Dip Resistor
Having a few problems with the headlights on my 2004 TD5. I acquired a pink lucas relay ywc 10050 off a scrap mini, whilst a new one was ordered. It worked fine till tonight !! No headlights only side . So fitted the new relay the side lights work but the headlights just emit a dull glow. The main beam works on flash. Tried googling the problem and it could be the dim dip resistor but the question is where is it located and does anyone know the part number ? I'm not very good with electrics and could not use a multimeter to save my life. Any suggestions ?
Post #605855 1st Mar 2017 9:15pm
dorsetsmith
Dim Dip Resistor
driver side wing you can see from engine bay
Post #605863 1st Mar 2017 9:36pm
Mo Murphy
Are you sure it isn't your headlamp switch that has failed ?
50 Shades of Pennine Grey
Post #605938 1st Mar 2017 11:55pm
Sounds a bit like it to me. ^^^^ ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #605941 2nd Mar 2017 12:10am
molecatcher
Thanks for the advice I will replace both and hopefully that will sort it
Post #605965 2nd Mar 2017 8:25am
