![]() | Home > Puma (Tdci) > Just had my first problems |
christyler Member Since: 10 Dec 2010 Location: Cork, Ireland Posts: 67 ![]() |
I am no expert, but it seems to me there is too many faults there and some conflicting ones. I have seen this type of thing before with a low battery voltage problem.
I know in might be stating the simple solution but have you checked the battery and terminals ? One of your faults was "low voltage" it could be that it was the cause of all the others. Its not likley that you have a throttel, MAF, comms, and turbo fault all at the same time. |
ring LR assist Glyn 2.4 90 XS
P0100 and P0299 faults are being rectified on my Landy on Tuesday by LR. The fix is a new EGR/Turbo harness as the wiring is stretched. LR now do a modified harness to solve this issue. Also getting a new EGR valve under warranty
The U001 and the P1643 appeared after I had been playing about with the nanocom, plugging it in and out a few times. These faults were reset and have not reappeared. The only constant faults I receive are P0299 and P1935 which should be fixed Tuesday! EDIT: P1103 Mass Air Flow Sensor In Range But Higher Than Expected U0300 Internal Control Module Software Incompatibility P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network P0562 System Voltage Low (Fault code under: Vehicle Speed, Idle Control and Auxiliary Inputs) P068A- CM/PCM Power Relay De-Energized Performance - Too Early (Glow plug circuit) |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Cheers for the input everyone..... now I am miffed!
Went for a short drive after deleting the codes and most of the codes have gone and not come back ![]() P167B- Fuel Injector Learning Not Done 068A- CM/PCM Power Relay De-Energized Performance - Too Early And 2 more have appeard ![]() P0606- Control Module Processor P0404- Exhaust Gas Recirculation "A" Control Circuit Range/Performance So looks like you are in the right area Bri..... Will call LR assist when I get back from UK this weekend..... Would much rather it go to a UK dealer (Ripon) for the work though (German LR dealers are complete W@NK). Will see how it goes. Glyn ![]() |
Glyn, don't reset these codes as LR will only do the warranty work with them showing on the ECU, so you should get a new EGR and wiring harness. You probably already know this but anyone else reading this post who doesn't know should be aware that the serious codes should not be cleared from the ECU as that is what the dealer basis the work on, ie No faults listed in ECU = No problems with Landy.
I can see that if I get a fault reader I'm going to be alerted to all the invisible codes that the system logs. I'll be driving around paranoid and worried the whole time
![]() Maybe I should live in blissful ignorance ![]() + New Defender 110 First Edition |
I have been... I guess that is why there were so many codes there like overboost.... All turbo cars do it every now and then, but when she cut out today I am glad I could read it as it gives me an idea what is going wrong ![]() Glyn ![]() |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
blame it to the Flipflopmechanic! WANTED:
SII or SIII in max 1.5k |
I must have knocked the EGR whilst changing the bumper! ![]() ![]() ![]() Glyn ![]() |
Download this one https://files.me.com/daniele.gardellin/vbutqe your P1103 isn't correct!!! P167B- Fuel Injector Learning Not Done you have done Q068 but dealer do not done injectors learning (same mounths ago LR system given errors on this procedure) P0562- System Voltage Low battery related to the cold temp not a real problem P068A- CM/PCM Power Relay De-Energized Performance - Too Early see previous point P0234- Turbocharger/Supercharger "A" Overboost Condition normal on all Puma that I have seen P1103- Mass Air Flow Sensor In Range But Higher Than Expected normal on all Puma that I have seen P0100- Mass or Volume Air Flow "A" Circuit related to BAS remap but not really a problem new version are ok now, write to Pete P0299- Turbocharger/Supercharger "A" Underboost Condition normal on all Puma that I have seen U0001- High Speed CAN Communication Bus related to BAS remap but not really a problem new version are ok now, write to Pete P1643- CAN link to ABS ECU.Implausible signal/condition U0300- Internal Control Module Software Incompatibility related to BAS remap but not really a problem new version are ok now, write to Pete Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hmmm, I better write to Garry.... Don't think Pete will do much for my Alive Tunning re-map thingy ![]() I wonder why it cut out on me today then. Maybe time for a good service after being in the cold for so long ![]() Glyn ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Thats what happened to me. EGR...blank it by a remap...ignore the fault, get a new one (how much) or what? Mike |
Did you short circuit the power supply of the wich shortly or so?
Is just the fault codes or is it driving faulty? WANTED: SII or SIII in max 1.5k |
Is that at me? Driving fine - except changing MPG - everyso often it logs either EGR stuck open or Stuck Closed. I think there is an intermittant fault (i did ask the dealer though, when in warrant, so dont start me!) Mike |
