![]() | Home > Puma (Tdci) > Random Bolt |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5103 ![]() ![]() ![]() |
How big is the nut? Mike
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Might just be spare from when made I found 1or2 floating about.
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
isnt that the master bolt nut, you know the one that holds the two sides of the chassie together?
sorry i'm a child i know, it does look like the nuts that are used to hold the tie down's, i know they are used in other places, just not sure where. |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Yup, looks like a lashing eye nut.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
primary gearbox mount retain nut......is it about an M6 - M12 in size?
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
lashing ring nut, should be under your vehicle. WANTED:
SII or SIII in max 1.5k |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
![]() I've found the same at the same place, I've put it in the cubby box tilt I know where it came from. ![]() |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
pha...... you lot know nothing. it's the doubry nut that's holds on the ferkin thingy
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
Ha it is smaller than a rear door bolt I know that. Washer is attached but it spins. Clearly my truck is going to explode.
It's a gift from land rover to you
![]() + New Defender 110 First Edition |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
![]() Click image to enlarge Check one of these nuts. I had the same gift by LR. Ciao Vinicio Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
prob been rolling around since it left the production line as no spanner marks etc on it. 2.4 90 XS
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
I found 3 of them...1 was under the plastic surrounding the windows causing an irritating rattle that the dealer could not find.
I am taking the plastic off this weekend to see where they come from. |
