![]() | Home > Maintenance & Modifications > Swingaway recommendations |
Mantec one is very good. Bearmach is cheaper but not quite up there in terms of quality. Safari Equip does one but I've heard of several people having issues with it. Their other gear is well made however.
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Nice to have a 'SYF'
Ade, I have the nakatanenga one fitted to my Landy. It is very well made from steel first galvanised before being powder coated. Where the swing away arm meets the guide plate both bits are stainless steel so when the powder coat wears away it wont rust. The weight of the carrier and wheel is carried by the cross member with all the weight removed from the rear door. Here is the thread I done on fitting it:
http://www.defender2.net/forum/topic4659.h...el+carrier HTH Brian. |
Nice job Bri.
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
There is also this one
![]() ![]() Click image to enlarge |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Thanks chaps. I've also now bothered to find the previous threads on much the same subject and there's plenty to chew over.
Sorry for duplicating a much-visited subject ![]() |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Have to say, I've got the Alisport / Sonic one, and cannot recommend it highly enough. Strong enough to carry at least 2 wheels piggy backed (with longer bolts - if you needed too), smooth, well made, and all the weight on the crossmember.
Bloody heavy though - you MIGHT want a wee hand to get it installed - just 2 minutes help until the main bracket is mounted. Yes it is more expensive than the rest but you get what you pay for. (Right Sonic, when do I get my commission ![]() |
How about several beers if you visit us at any of the shows ![]() |
I have the Mantec one.
Does the job very well but my powder coating is coming off in parts (around the hinge) after 3 years. Bit disappointing. I wouldn't be without one - rust or no rust. Sonic's looks good but wasn't available when I bought mine. important that it stays attached to the back door. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
The Sonic one does not attach to the back door, thus making it ideal for tailgates. It simply open completely independent of the vehicle, with all the weight on the crossmember, nothing on the tub, and no drilling into the bodywork, or anywhere else as it uses existing holes in crossmember. 2001 TD5 110 DCPU in Bonatti Grey |
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 ![]() |
What is the cost of the Sonic one please and any other pictures of it?
ebay item eBay Item No. 330484485039 if you do a forum search there is a thread which sonic started with loads of pics. |
Thanks Mike.
SR Some pics in my gallery - excellent bit of kit ![]() Bob |
