Home > Technical > Alternate puma fuel filter?
oburrill
United Kingdom 2013 Defender 110 Puma 2.2 SW Corris Grey
Hello, just a thought, but the standard Defender puma fuel filter is WJI500040, which says 5 micron.
The WJI500030 is the fuel filter for the 2002 to 2012 Range Rover TDV8, and i'm sure this says 2 micron on it.
They look basically identical.
Any ideas why they use a 5 micron filter as standard on the Defender?
Would the 2 micron filter go straight on? Possible drawbacks?
Thanks.
Post #594481 19th Jan 2017 5:10pm
Bluest
Personally, as a layman unless there is some reason why the standard filtration in inadequate I wouldn't change. I'd be worried about the the finer filter putting more stress on the fuel pump or restricting flow or something. That's unless you can find a technical expert to say it's fine to swap. 2007 110 TDCi Station Wagon XS
Post #594497 19th Jan 2017 6:13pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I fitted a second filter...
Have a look at the thread http://www.defender2.net/forum/topic48466.html Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #594622 20th Jan 2017 5:56am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I did some homework on this a few months ago. From a few online sources I learned that all transit 2.4 /2.2 tdci filters are 2 microns (as it is common rail and uses very high fuel pressure) Whereas the di uses a 5 micron filter.
I fitted a genuine ford filter for the tdci - its a little bit longer than the rover branded version but in my view better. 1953 80"
1987 mini city e
2011 90"
Post #594851 20th Jan 2017 10:35pm
agentmulder
Kuwait
^^ Interested to know why it is better? Solved the bowel problem, working on the consonants...
Post #594875 20th Jan 2017 11:26pm
