Home > Tdi > TD5 seat box to fit TDI
MetalMatt
United Kingdom 1989 Defender 90 300 Tdi HT Baltic Blue
As said in the subject, i have a TD5 seat box to fit in to my 90 that has the fuel tank under the drivers seat, what do i need to cut out on the base of the TD5 seat box so that it will fit over the fuel tank.
cheers
Matt
Post #593805 17th Jan 2017 1:25pm
davew
Just the box under the driver's seat, you don't need to cut it as such, just remove the rivets and, IIRC, a couple of spot welds.
You will also need to create a filler panel as the resulting hole is larger than the cover plate. http://www.yorkshireoffroadclub.net/
Post #593816 17th Jan 2017 2:39pm
Retroanaconda
You'll need to make a plate to fill I'm around the transmission tunnel too as the one that the Td5 seatbox usually attaches to is far wider than the 200Tdi one, so there will be a gap.
Post #593895 17th Jan 2017 7:47pm
MetalMatt
cheers Smile managed to remove the under storage box lots of drilling out rivits Twisted Evil
Post #595634 23rd Jan 2017 5:52pm
