![]() | Home > Maintenance & Modifications > Fitting second row puma seats in a 300 tdi |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 297 ![]() ![]() |
Hi,
Looking for a bit of advice regarding fitting tdci second row seats in a 300tdi 99 110 csw. They came fitted in the vechicle when I bought it however they were only fixed to the ali upstand/floor ![]() http://www.brit-car.co.uk/product.php/1414...upport_def However I can't work out how/if it would fit my 300tdi. Any pointers would be great Cheers Leigh 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
tiger & Mk1 collector have both done this check out their build threads! My 109 thread
my youtube channel |
![]() 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
I've just googled some pics of a tdi chassis and it looks like the crossmember should bolt straight on and the two brackets you linked to (which are the correct ones) should fit but could need a bit of modding if the angle of the crossmember they bolt to is different (can't really tell from the pics) you could always weld them to the crossmember in the correct position and it will definately be safer than just bolting to the upstand
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thanks for the info
![]() Cheers Leigh 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
