![]() | Home > Maintenance & Modifications > Diff pinion height |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
Probably not, but best to check tooth engagement with engineers' blue.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
More than likely it will be the same height, but whenever I build a diff always check teeth engagement using engineers Blue and rolling resistance of the pinion itself then with the crownwheel assembly fitted
Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
