Home > Maintenance & Modifications > Advice on Feeding USB chargers etc
pjb
Hi
I have installed via an auxilary fuse box a suppy to a double USB charger & a battery voltage meter & my dash cam.
The idea was to leave as a permanently live supply but have decided not sensible as when left for a week they along with the tracker etc etc help flatten the battery.
So what I would like to do is either have the supply that stays on for say 60 minutes after the ignition is turned off, or have it such that it turns off once the battery is below say 12 volts.
What do I need to do this any suggestions as to the best way ?
If it makes any difference the fuse box is in the passenger seat box next to the battery
The plan is also to feed another USB charger & cigarette lighter socket at the back of the cubby box for rear passengers to use, and would want to power these by a similar nature.
Cheers & Merry Christmas 2020 P300 HSE
Post #586299 19th Dec 2016 9:21am
macfrank
Hi,
I was about to install some "zero-standby" switches along with the various aux/usb supplies I'm going to install.
But I prefer your approach, the timer in particular.
Currently I have a simple low voltage disconnector to prevent the fridge etc. to drain the second battery.
This seems to be a good read: https://dashcamtalk.com/battery-discharge-prevention/
Many products even seem to combine voltage thresholds with a timer!
Thanks for putting another item on my to do list Thumbs Up
cheers
Frank
Post #586317 19th Dec 2016 12:03pm
pjb
Thanks Frank
A good read. Thumbs Up
My concern is they are all for dashcam type outputs - so quite small, I'm not sure if they are heavy duty enough for what I'm looking for Exclamation although I could perhaps use it to control a relay Question 2020 P300 HSE
Post #586319 19th Dec 2016 12:12pm
macfrank
ah, you're so right - 1A Sad I think the little device I have, might also just be good for 5A.
This seems to be more like it
http://www.dmsshop.co.uk/rflvd10-low-volta...-269-p.asp
There are variants of upto 200A Twisted Evil
No timer though and I can't find the voltage thresholds, can you?
Maybe you'll find something similar?
Post #586321 19th Dec 2016 12:25pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Although not particularly cheap, its exactly the thing that you want:
http://www.12voltplanet.co.uk/adjustable-d...v-10a.html North Cumbria Search and Rescue - Team Leader
Post #586335 19th Dec 2016 1:45pm
macfrank
Thumbs Up
I like the automotive spec. But pricey indeed.
May be I'll chain one LVD20 or 40, some switches and one of the timer relays. Hmmm.... Confused
Post #586341 19th Dec 2016 2:34pm
VeeTee
Netherlands
Just out of curiosity, what would be the purpose of this set up? What appliances would be powered for one hr after ignition is switched off? Cheers, Vincent
MySite
Post #586389 19th Dec 2016 7:33pm
DuncanS
Very handy if you're nipping out to the shops with the kids still on board, busy away flattening their phone batteries but you don't want to leave the keys in. North Cumbria Search and Rescue - Team Leader
Post #586390 19th Dec 2016 7:35pm
VeeTee
Netherlands
Ah, I see... I have a very sophisticated solution installed for that purpose: a manual switched USB outlet on permanent live. Wink Cheers, Vincent
MySite
Post #586391 19th Dec 2016 7:39pm
Driving a relay to switch on the fused power supply would seem to be the easiest solution. Darren
Post #586420 19th Dec 2016 9:13pm
jst
a voltage sensing relay such as the likes durite sell would do it Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #586422 19th Dec 2016 9:23pm
pjb
thanks gents
A voltage sensing relay it is Thumbs Up 2020 P300 HSE
Post #586484 20th Dec 2016 9:22am
