Home > For Sale & Wanted > [For Sale] Steel loft access panel for sale
LR90XS2011
anyone renovating a house and need a Loft Access Panel , I purchased one and did not use it because it had a very small dent cause by the delivery company, the dent wont show up in photographs and it could be used as is or filled and painted.
It is all steel has an insulated door and fits a hole 520 x 740 mm. I replaced it with another exactly the same that I got as a replacement from the manufacturer.
If anyone wants the original you can have it for £30 which only covers my petrol and time collecting the replacement.(didnt want to trust the courier again)
I would highly recommend this company in terms of product and customer service, they just use a poor courier.
I will make a £5 donation to def2 if it sells on here, and would prefer some one picks it up or I can deliver locally by agreement
Below is a copy of the correspondence with the supplier regards the original price.
We can supply our APD.LOFT.50PF.3WL (Insulated Loft Hatch, Metal Door with 50mm Picture Frame Surround, Non Fire Rated with 3 Point Locking System, RAL 9010 30% Gloss)
1 No - 513 x 733mm Hinged Short Side (To suit a structural opening (hole size) of 520 x 740mm)
£128.42 + VAT
Loft Hatch with Picture Frame
APD.LOFT.PF - Delivery 3-5 days
Loft panels are designed to fit into any type of ceiling system in order to gain access to domestic loft areas. The rear of the metal door tray is fitted with 65mm thick, foil backed insulation board with a thermal conductivity value of 0.023 W/mK.
A 50mm wide picture frame surround is provided for retrofit. This enables the panel to be inserted directly into the clear structural opening and screw-fixed into position through the side of the panel frame.
Specification
Manufactured from 1.2mm thick Zintec Steel frame and 1.0mm thick Zintec Steel door tray with polyester powder coating of matt white RAL 9010 20% gloss. The door has a concealed continuous hinge, and is secured using either a standard budget lock or pull latch (please state which option is required).
Fire
This is a non-fire rated access panel.
Section View
APD.LOFT.PF
if anyone is interested please PM me your e/mail and I will send you loads of photos DEFENDER 90 TDCI XS,
Post #585990 18th Dec 2016 8:36am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Funny enough I broke our plastic one last week... I will measure ours but think it's bigger... Will report back later V8 90...WIP
Post #586014 18th Dec 2016 10:06am
