Home > Maintenance & Modifications > sand ladders as security screens on rear windows
xcentric
Anyone come up with a simple, cost-effective solution to storing the sand ladders on the side so that they also act as security screens over the rear side windows? There is a commercial product but its about £120 a side....
Post #585915 17th Dec 2016 10:46pm
Pilgrimmick
Temp or permanent fit? 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #585924 17th Dec 2016 11:24pm
Sulisuli
Could you use or modify something like these perhaps?
Having used these to hold the ladders in situ use a padlock thru the thumb latch to secure it and prevent removal perhaps? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #585927 17th Dec 2016 11:33pm
xcentric
ta so far.
in terms of temp versus permanent - they need to be removable as I may need to use them Laughing
the fastening looks good (tho not quite sure what the first one is for - backing plate?) - assume they would attach to bodywork just above and below windows. But will the alu body be strong enough to support the weight on rough tracks without widening and ovaling the holes?
Post #585936 17th Dec 2016 11:44pm
Sulisuli
The first is the plate normally welded to the trailer tailgate which the thumb latch passes thru before being closed and I only posted the picture to try and show what I was suggesting, I guess on sand ladders there are already so suitable holes the thumblatch could pass thru prior to being closed?
Perhaps the use of a backing plate would help distribute the weight on an alu body? Perhaps a forum member with metal work knowledge or experience can suggest a suitable method for using the thumb latches? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #585943 18th Dec 2016 12:02am
Pilgrimmick
A decent sized backing plate wouls allow the catches to support the sand ladder, what type are you using, PSP, alloy?steel, waffle boards? 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #586031 18th Dec 2016 12:09pm
