Home > Maintenance & Modifications > Silly Question?
Albion
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Silly Question?
Morning
I'm not exactly in love with the door handles on my Puma. Would it be possible a) to replace the doors with doors from an older model, with the lift up handles, and b) still retain central locking?
Post #584960 14th Dec 2016 10:28am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
The doors will fit, central locking might be an issue, there was a thread on here where a kit was retrofitted to a rear door so I'm sure it's possible. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #584964 14th Dec 2016 11:02am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
The locks on the "lift up handle" doors are totally different to those on a more modern Landy - based on my experience of series vehicles. The big advantage of the older doors is they are split and you can remove the door tops, great fun when the weather is good and a big plus if you are doing the likes of vehicle trials. Getting a good set of ex military aluminium door tops won't be cheap, then you have paint, new interior trims etc etc. To do it properly and have a good factory finish - if that's what you're after - I think you would be the thick end of a grand anyway, then suss out central locking etc.
If you decide to do it I'd be interested in seeing just what you've done, take photos and post them on here Thumbs Up
Post #584979 14th Dec 2016 12:28pm
rallysteve
The lift up handle doors from the early 90s and slightly later 110s were single piece with lift up outer handle and inner pull handle similar to the later ones. It is possible to retrofit central locking to these if you so wished.
The older series style and early 110 2-piece doors have inner and outer lift up handles and could not be fitted with remote locking. 02' 110 TD5 Double Cab Rebuild Thread
Post #585092 14th Dec 2016 8:04pm
Albion
Many thanks to you all, and to RallySteve. Looks like I need to hunt down some doors!!!!!
Post #585097 14th Dec 2016 8:20pm
Tiger
Why couldn't you adapt a rear door central locking?
Rear doors still use SIII handles and they have remote locking
Post #585100 14th Dec 2016 8:43pm
^^^^ I was just about to mention the rear door lock. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #585102 14th Dec 2016 8:47pm
Whilst the handles are the same, the locking mechanism on the front doors is very different. It comprises a twist and push knob rather than the sliding latch on the rear door. Darren
Post #585114 14th Dec 2016 9:16pm
rallysteve
Have a look at sp landrovers. They do the doors, locks and door cards.
Post #585116 14th Dec 2016 9:23pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Good price, and good quality too.... Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #585124 14th Dec 2016 9:34pm
Retroanaconda
You should perhaps try a vehicle with split-doors first, it would be a retrograde step I feel.
They are a world away from Tdci doors and although they look good they quite frankly are horrible flimsy leaky draughty crappy things in my opinion.
The early 90/110 one-piece doors with lift-up handles and wind-down windows would still give you the desired effect but are an improvement on split-doors. However they're like hens teeth in good nick and still suffer from the catastrophic rot which blights all pre-2005 doors.
Post #585163 14th Dec 2016 10:51pm
Albion
Good advice Retro, thanks. Looks like this isn't going to be a straight forward process, so will take it one step at a time.
Regards
Post #585238 15th Dec 2016 7:46am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have 1984 doors with lift up handles in my 2003 td5 90.
I have no real experience with the Puma but it will be almost a straight fit if you change the door catch too. However most work will come after the actual fitting as you have to redesign the door seals and all the other parts that just don't fit.
It might be more work than you expected.
At least it was for me and I don't even have door cards and electric windows. Whistle
 Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #585269 15th Dec 2016 11:15am
