Home > Technical > Land Rover Painting Techniques
shaggydog
Hi guys,
One for the rivet counters today Shocked
When I went on the factory tour, I was told that the paint shop was built by BMW in 1996 with its dipping processes for cleaning, priming and then sort of undercoating the body shells as they rolled through on skids. Prior to that they were just hand sprayed with primer and paint.
I believed this to be true, however it does not explain what I found when I took my 1991 cappings off the tub.
As you can see, the body has had a spraying of top coat (Arles Blue) but underneath the capping there was a layer of primer/undercoat. What's more, under the foam seal between the capping and the tub was paint, so the paint must have been applied before the body went into the paintshop. This would indicate that the raw materials had been stamped out, spot welded together, painted, then the cappings added, then put on the skid and sprayed.
So, whats happened then?
Indeed at the factory I could see the bare body panels being spot welded together, then the foam seal being stuck on, then the cappings added then it going off to paint which would logically dictate that if you were to remove the cappings on a post 96 defender and peal back the foam strip(if present?) you would see bare aluminium.
As I say, anoraks on and rivet counters gather! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #583225 7th Dec 2016 2:24pm
Retroanaconda
My 1992 is the same, primer under the cappings.
I am led to believe via hearsay that 'newer ones' are bare metal underneath, and while it wouldn't surprise me, I haven't actually seen one dismantled with my own eyes to confirm it.
Post #583247 7th Dec 2016 4:27pm
shaggydog
That is also my belief too again via hearsay.
So does this confirm my theory that the tubs were primed before the cappings were put on?
Can anyone confirm for certain? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #583466 8th Dec 2016 1:35pm
To be honest, I think that picture is all the confirmation you need. It couldn't happen any other way. Darren
Post #583470 8th Dec 2016 1:50pm
