![]() | Home > Maintenance & Modifications > Battery box rust |
A rust killer treatment and then paint for an area like that. You don't want a liquid finish like ACF50.
I've got to do the same to mine but I'm waiting for warmer weather before embarking on painting projects. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Conan Member Since: 05 Sep 2016 Location: the danger zone Posts: 53 ![]() ![]() ![]() |
Thanks for your input LandRoverAnorak.
Do you recommend any product un particular for the rust killer treatment? Would a rust converter (like the dinitrol RC800) work for this operation? |
Not particularly, to be honest. They all seem to do much the same thing, as far as I can see. The Dinitrol product gets good press but I've had good results with Kurust from Halfords. Darren
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 ![]() ![]() |
Kurust and then hammerite is what I used for my battery box which had far more rust that that. I was very liberal with the Kurust and allowed it to run into the battery clamp 'grills' on the bottom (with a cloth underneath the vehicle to prevent marks on the drive !) - juts make sure its no already full of mud / dirt so get the hoover in there first !
Thanks both for your input. I got myselft some Dinitrol as I will use more of it when I treat my chassis.
The product is on its way, and I will paint the battery box by the end of the week! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
Kurust, black Dinitrol wax.
Done mine a while ago after fitting Dynamat under first. ![]() ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Hi custom90steve, did you cover the whole box in dynamat? I read a while ago (i think t was on this forum) that it wasn't recommended to cover the holes as there could be some chemical reactions with the battery, if there was no air circulation...
I was thinking about putting a layer of dynamt on the lid of the battery box (under the seat) later on (dynamat is on my to do list), but that wouldn't affect the box itself I think... |
Does dynamat have that foil covering over it? You wouldnt want a short across the battery because the terminals hit the cover! I used some thick rubber sheeting cut to shape and stuck to the bottom of the battery box cover
Yes, foil.
I did just the base inside only for that reason, and the lid under and over taped around the edges. It'll never get near the battery terminals on mine. No point in Dynamatting the inside other that lid top and bottom, and the seatbox base. The sides and inner top of the seatbox is no point if you Dynamat the outside lie I did instead. The base is quite a resonant flat panel without doing it. There is some vent holes there IIRC, I covered them bar one, a larger one if I remember rightly. The battery has a breather anyway, or at least it should! ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Photos for Y'all
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
that looks pretty neat! thanks for the info and pictures. I know what I need to do now!
I finished the battery box this weekend. I'm happy with the end result. I added a stripe of aluminium tape on one edge that looked exposed to prevent contamination by dirt... i don't know if it was necessary though...
![]() Click image to enlarge ![]() Click image to enlarge |
