Home > Puma (Tdci) > 2 years of dry right foot, now wet:(
Andrea
Hi there guys.
I have a 2009 defender Puma, i am extremely happy with the car, and recently took it all the way to the serengetti(from cape town) covered about 14000ks, without a hiccup... well sort of! Never mind that the shortie towed a gearbox failed land cruiser for aprprox 600ks to rescue it!!
Anyway on my way back< went through significant rain, and for the first time in 2 years i got a drip on my foot! I since took it back to the dealers, and after having re-sealed the windsceen mounts, the seal between the windscreen and the firewall, the water is still appearing...
Does anybody have a clue as to where this water is coming in? or is it via osmosis? Laughing
Regards.
Post #52944 14th Jan 2011 2:01pm
bob neville
Hi Andrea
I have had the seal between the windscreen and bulkhead replaced, leak one gone, the heater box resealed, leak two gone, the door seal replaced, leak three still there but very minor. With a bit of careful adjustment on the door seal I think I can resolve this final leak as well. The area on the door seal that is causing my problem is at the front about half way down where the curve of the wing is. Water gets in here and then seeps along behind the dash.
Get the dealer to seal the heater box and check the door seals.
Bob
Post #52964 14th Jan 2011 4:17pm
alantd
bob neville wrote:
Hi Andrea
Bob
Do you know which bit of the heater box they sealed? Mine's now out of warranty and I've still got a slight leak into the passenger footwell, which I'm convinced is coming from the heater box.
I installed a snow cover because I originally thought it was coming in from a blocked drain plug and sealed all around the heater intake to prevent the wings dumping water into it but it's still not resolved. I wondered whether it was coming through the bonnet hinges and dripping onto the heater box.
I guess I have 2 tasks: stop the water getting onto the heater box; and seal the heater box so that water getting onto it doesn't end up in my wife's bag One that started out as a 2.4 TDCi 110 XS
Post #53643 18th Jan 2011 3:43pm
bob neville
"I wondered whether it was coming through the bonnet hinges and dripping onto the heater box. "
Alan
That was the problem my dealer identified. They removed the box from the bulkhead and resealed that.
Bob
Post #53644 18th Jan 2011 3:46pm
alantd
Alan
Bob
Genius. Ta.
I'll try and seal the hinges first Wink One that started out as a 2.4 TDCi 110 XS
Post #53656 18th Jan 2011 4:27pm
bob neville
Alan
The leaks into the passenger footwell on mine are 99% fixed. The last change by the dealers was the door seals but I still get a small amount of water in if the rain/wind is blowing from the wrong direction. I know it is the door seal as I can see where the water enters the vehicle. I could use sealer but would like to try and find out where the seal is failing. Also, if I park with the passenger door out of the wind the problem stops.
Once the water is in it finds it's way along the dash and drips in the centre of the footwell - it looks like it comes from the heater but in fact does not.
Maybe Pete from Nakatanenga could post a reply and let us know if the door seals he supplies would resolve this type of problem ?
I, for one, would pay the money to get a set of door seals that stop water getting in Thumbs Up
Bob
Post #53689 18th Jan 2011 6:09pm
