Home > Maintenance & Modifications > Adding Alpine & Rear Quarter Windows?
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Has anyone added Alpine and Rear Quarter windows to a non-county HT?
I assume it is as simple as cutting the correct size holes in the right place and fitting both the rubber seal and the glass but wanted to check before jumping to that conclusion.
Post #581085 28th Nov 2016 2:51pm
Correct, but the location and size of the holes is critical. I am told that the Alpine lights are especially difficult to get right, and are especially difficult to fit.
The rear quarter windows, assuming you mean the two little windows on either side of the rear door, seriously compromise the security of the vehicle, since they can be removed without tools in under 5 seconds. I would not fit them to one of my vehicles unless I also fitted some kind of security grille.
Post #581089 28th Nov 2016 3:22pm
CarMan
I wanted to do just that.
Urban have advised they will not do either, which I find odd as I am sure they have in the past.
Anyway, my local independant has just done it on a brand new 90HT apparently without drama, but I understand you have to use older type alpine fittings as the new ones are for roofs with a preformed shape for the alpine windows.
Being a coward I think I have pretty much canned the idea Big Cry Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #581094 28th Nov 2016 3:46pm
Mr Fox
Cheers Blackwolf, I assumed that would be the case.
CarMan, I've got faith in my local window shop but I know I'm taking a risk.
If I end up with one without windows, I'm going to try living with it but I wanted to know if there was an easy solution if I found light and visibility an issue. Thumbs Up
Post #581138 28th Nov 2016 7:04pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Try these Thumbs Up
https://www.landroverdefendersecurity.com/...ndows-only 2010 Defender 90 HT
The longer I live..... The better I was!
Post #581139 28th Nov 2016 7:13pm
I fitted alpines to an old plain hardtop 90 I had some years back.
Just a case of measuring off of another roof that had the holes in it, then cutting.
Use that special tool to get the rubber "inner" bit in place, along with some washing up liquid for lube. Easy job.
Post #581144 28th Nov 2016 7:23pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
I fitted alpine's to my old 90td and also side windows. Just make sure you measure more than once before cutting, take your time, I used a jig saw but if you have access to a nibler it will be a lot easier. The hardest job was fitting the thin insert without the proper tool, especially as I fitted it to the inside of the vehicle as a deterrent to those who wish to gain acces. Take your time and be patient. HTH. Regards
Dennis.
Post #582309 3rd Dec 2016 12:01am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Yup. I have fitted them all. Easy really, but the alpine glass is hard to install. V8 90...WIP
Post #582311 3rd Dec 2016 12:21am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Speak to Dave at VGS he can do them for you 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #582379 3rd Dec 2016 1:10pm
