Home > Maintenance & Modifications > Security upgrade or potential PITA?
grafty99
Morning all,
I had a little idea last night and wanted to know people's thoughts.
I was thinking of installing a microswitch inside each door that earths the door switch wire when the button is pressed or handle is lifted to open the rear door.
When the alarm is activated, attempting to open the locked door by trying it would set off the alarm. If it was me then obviously I would know it was locked so wouldn't try it but an opportunist would set the alarm off and hopefully they would then think twice?
Just an idea for another layer..... 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #581035 28th Nov 2016 9:58am
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
Sounds a good idea on the face of it. How doable may need some thought. Been awhile since I did any electronic stuff. Regards
Dennis.
Post #581487 30th Nov 2016 1:05am
grafty99
I would have thought it would be pretty doable. The door trigger wires just need earthing to trigger the alarm. It should just be a case of mounting the switches. I'll whip the door cards off this weekend and have a look Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #581516 30th Nov 2016 9:11am
I think it is an excellent idea and, provided that mounting suitable switches is not too difficult, should be easy to wire up and pretty effective.
Since there is no reason at all why anyone other than you should ever press the door buttons then I think that making the alarm sound is a sensible option. Better still rig a camera in the vehicle to photograph the person doing it.
If you proceed with this scheme, I'd be interested to know what switches you use, how you mount them, and how well it works. Thumbs Up
Post #581527 30th Nov 2016 9:43am
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
One reservation about this plan: quality of the micro switch.
I used to own a car made by a small UK company; a lot of their parts were bought 'off the shelf', rather than made for them, because their production volume was under 1,000 cars per annum.
The one reoccurring issue I had with the car was the micro switches in the doors. Over a five year period, I had to have them replaced three times and I wasn't alone in having this issue - it became a known fault.
I don't know who produced the micro switch for them but they did seem to be quite 'fragile' and unreliable; therefore, I'd look to but the best quality ones I could and even then, be wary that they may be an easy fail point and create issues.
Sorry to be the devils advocate but they were the bane of my existence and were the last thing I would add to a cars door by choice. Confused
Post #581537 30th Nov 2016 10:14am
