![]() | Home > For Sale & Wanted > Fs ARB pegged diff |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
As title im selling on behalf of a friend an ARB locking diff which is in a pegged housing recently rebuilt with new barings and seals ready to go. 3.54 ratio 24 spline used but in good working order.
This is a private sale no i cant accept paypal or visa card to my business, it will need to be cash on collection or bank transfer. my friend will accept paypal if the payment is sent as a gift and you pay the charges. The cost is 600gbp with free UK shipping. This would normally cost when new 1140+vat as you see it here as per the Ashcroft web site. ARB, Manual locking diff Where an application requires that the diff must be able to act as an "open" diff and a fully locked effect, the only solution is to fit a manual locking diff under the control of the driver. These diffs need additional external parts, compressor/pipes/ solenoids, etc ![]() Click image to enlarge ![]() Click image to enlarge A method of strengthening the Rover differential If you are heavily off roading your Rover one of the first mods you will need is to change the diff centre for a stronger one be it either Detroit locker, ARB or other, once you have the diff centre up rated you may still experience a failure of the crown wheel and pinion gears. The reason for the ring and pinion failing is because when the diff is shock loaded, the pinion will push the crown wheel away as the diff centre flexes, once the pinion teeth start to ride up the crown wheel teeth this can allow the pinion to spin and take some teeth off either gear. "Pegging" the diff to hold the gears in constant mesh by putting a thrust pad behind the crown wheel, opposite the pinion, this means the pinion cannot push the crown wheel away. ![]() Click image to enlarge ![]() Pete Last edited by bell-auto-services on 13th Jan 2011 7:32pm. Edited 2 times in total |
Like im not trusted lol, i have the diff here ill personally be sending it and i can assure the buyer i aint gona rip you off for 600 quid.
But POM your point is fare i think however in this case its not needed. Pete |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
didn't mean to infer you would Pete!
Just I see more and more ebay ads, sales ads and stuff with this on and people arnt aware its an issue until something goes wrong and they are stuffed. Pom |
You havent offended me mate, this is the reason i added it to the forum my self and have the item here.
To protect the buyer as i will be sending it out. Pete |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8397 ![]() ![]() ![]() |
3.54? Cheers
Yes mate, sorry i didnt think to add
![]() 3.54 24 spline Pete |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Bit of a strange question.... How much does it weigh?
Thanks, Glyn ![]() |
ll try and weigh it but i think 20-25kg
pete |
Just that my baggage limit is 20Kg, would like to find out and see if it works out OK with excess baggage etc
![]() Glyn ![]() |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Would this fit a Discovery 1 300tdi please? Andy
Im not sure about the 300TDi, you would need to remove a rear half shaft to see if you had 24 spline shafts ot 10 spline, 300 is on the change really.
Pete |
Ill get it on the scales tomorrow.
Pete |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
Pete you have mail
Sold confirmed. Thank you.
Pete Last edited by bell-auto-services on 13th Jan 2011 9:19pm. Edited 1 time in total |
