![]() | Home > Technical > Weather and alarms |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 ![]() ![]() |
Happened to me too this morning. It was chucking it down. Don't remember it ever happening before. I've had a trapped moth set it off though.
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
Are you sure its the ultrasonic sensor?
More likely than not, its the bonnet sensor. The metal bracket that holds it in place can bend or the switch can become damaged/worn out. All it takes is the vibration of heavy rain hitting the bonnet and it sets it off ![]() |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Do you get rain water in the passenger footwell? Regards Mark. |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 ![]() ![]() ![]() |
No water no, I used to have that leak but managed to sort it a while back!
Cheers, Lew |
01rwilkinson Member Since: 22 Nov 2016 Location: Lancashire Posts: 23 ![]() ![]() ![]() |
Hi there I have the same problem, bad weather ,hail ,hard rain . sometimes
If I forget to disarm alarm,jet wash sets her off . I will occasionally sneak up on her and bang on the side ! Just to see if she's awake ,you know strange lot handymen! Almost makes you feel good to be alive strange!!!😁 |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Sub-zero temps this week, and with the car not driven for 2 days she started first time of asking but the alarm sounded transiently.
Following this, I get a notification from Skytag that the battery had been disconnected. I take it this was because of battery power being briefly completely drained from all other systems to supply the starter motor to turn over a (very cold) engine? Is it an early sign of an ageing battery (only 3 years old though) or something or nothing? |
