![]() | Home > Maintenance & Modifications > Hood and sticks question |
do you have gav hoop with it ?
Is hood cab fit or body fit cab fit in to a gav Chanel around back window , body fit in to gav Chanel fitted at the front tube behind cab |
alpacaman Member Since: 07 Mar 2016 Location: Gloucestershire Posts: 160 ![]() ![]() |
The very brief description suggests it includes the hoops. Not sure if it's cab or body fit - looks like body fit from the photo. It's a take off so I'm hoping the guy will have the bits - but it would be good to know what to look/ask for in addition to the hoops and the canvas.
oid post with pic showing hood and sticks body fit
http://www.defender2.net/forum/topic5443.html?view=previous link below shows fitting for hood and stick and part number http://www.allbrit.de/UNI.cfm?PAGE=765594&SPRACHE=EN Last edited by dorsetsmith on 15th Nov 2016 6:26pm. Edited 1 time in total |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Assuming you have the hooks and cleats on the top of the tub for the rope/straps then the other part you will need is the galv rail which bolts onto the back of the truckcab and the top of the tub (along with the dzus fasteners and angle section to hold the front of the roof down) these are mega money new but do come up on ebay occasionally. I doubt you have one fitted as the Ifor Williams top doesn't fit with it still in place. You might also need to modify your spare wheel bracket if it fits on the bulkhead as the wheel will now rest against the rail rather than the bulkhead.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks chaps. Will make sure I get every last bit of metal he's got when I go to collect it, then see how I get on. Planning to fit a swing away for the spare anyway so that won't be a problem.
Just checked with the seller. It does include the hoops and the full width drainage channel. No clamps apparently, but I believe I can get those from Exmoor should I decide to replace my Ifor Williams top with it.
Looks like it could have been a good buy. |
Thanks. Yep, they look like the fellas.
