Home > Maintenance & Modifications > Under-door seals
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
Under-door seals
Hi there,
Following on from a couple of soundproofing threads recently, I wonder if anyone can point in the right direction of a part. In my 90 I'm able to see the road through the bottom of both drivers and passenger doors, and I'm sure there is a fair amount of road noise coming through here (especially in the wet). So my question, is there some sort of seal that goes along the bottom of the door to seal this up, is there an oem part or is it aftermarket only?
Thanks,
Lew
Post #577266 12th Nov 2016 10:39am
dorsetsmith
LR029309 - DOOR WEATHERSTRIP LOWER FRONT DEFENDER late 2010 onwards i stand corrected Thumbs Up
Post #577267 12th Nov 2016 10:45am
Lew-M
Thanks very much! Should these be on the doors already or were they an option? Laughing
Post #577268 12th Nov 2016 10:46am
dorsetsmith
if not fitted to the door the only option is fit one Thumbs Up
Post #577270 12th Nov 2016 10:51am
they were fitted from late 2010 onwards, before 2010, they were the same as the TD5's
Post #577274 12th Nov 2016 11:13am
Lew-M
Mine is 2012, but doesn't appear to have them, but it is a county "farmer spex" maybe missing on these? Shocked I guess it would aid drainage from in to out Laughing
Post #577275 12th Nov 2016 11:14am
dorsetsmith
this one good read on the lower door seal
http://www.defender2.net/forum/topic6370-45.html
Post #577280 12th Nov 2016 11:32am
Cupboard
I have a poverty spec 2011 that has them.
Been through bonnet deep water (I wouldn't have gone through if I'd realised) and been the only person with a dry interior. I did have to laugh at the usually smug Toyota owners Very Happy
Post #577292 12th Nov 2016 12:37pm
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
can these be retro fitted to earlier 90's defenders?
Post #577995 15th Nov 2016 8:41pm
Stiff1
I remember a thread on here where a member retro fitted them.
Post #578033 15th Nov 2016 10:25pm
HardCharger
I have a 2011 D110 SW and the seals are still the old type. Rubber strips with foam rubber cubes at the ends. I'm actually planning to "upgrade" to the newer seals once the coin presents itself as they are a bit expensive if shipped here to where I'm currently assigned.
Post #578073 16th Nov 2016 2:05am
itolond
Hi all,
so if am reading correctly there should be no huge issue beyond a fiddle to get these retro fitted to a 97 Def, is the a rear door version as well? (S/W)
i am removing the doors for a complete overhaul and thought this would be best to do at the same time
Post #578080 16th Nov 2016 4:13am
Stiff1
I believe it is not so straight forward on an older model as the shape of the door changed at some point and it is this later profile that readily accepts the newer door seal.
Link found.
http://www.defender2.net/forum/topic6370.h...p;start=45
Post #578092 16th Nov 2016 7:32am
Martin
Site Admin
Those with the fabricated frame doors probably can't have them added as the bottom of the door is a sharp corner rather than the radius these are designed to fit.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #578133 16th Nov 2016 10:09am
itolond
yes my door profile is the square welded type - what are the alternatives?
Post #578194 16th Nov 2016 3:26pm
