![]() | Home > Td5 > Heater Output poor |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
My heater output is about as warm as a glow worms derriere
Is this just a TD5 foible or is there something (easy & cheap ) I can do about it? Even when the engine temp is just below half way ( normal ) it's warm at best. Where's me coat..... |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 ![]() ![]() ![]() |
Have a quick check for any stretch on the wires from the controls to the box.
If they are stretched or the fitting is loose the rod wont be turning as much as it should when you flick the lever down. Thus not being on fully. After writing this I'm second questioning if the heat is a setting by wire, but worth the check anyway! ![]() A wee guide to the correct wire. no. 13 http://new.lrcat.com/#!/1228/12822/13493/1049/13536 Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW ![]() |
I followed the first post on the link below and it sorted the heater on my TD5.
http://forums.lr4x4.com/topic/33481-feelin...ntry323899 Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Be sure to check your thermostat operation as well. If not operating properly, you wont get much heat. it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
When they're working well they are good, infact I find myself backing the temperature off on mine and that's in a 110 station wagon! You will find that in traffic the heater output isn't as good as general normal driving
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I fitted a new fan and a bilge blower into the inlet on mine and a hi flo inlet. With it properly adjusted so it gets full heat it all makes quite a difference.
I do have to wait for it to start reading a temperature before turning it on full, otherwise it never gets really hot. It really is plenty now 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Could also be a sign of head gasket gone so check that too 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
The Td5 heater is more than adequate when properly sorted. Check everything listed in previous answers and make sure it is set up correctly. If you still have little to no heat start looking at the engine (head gasket, thermostat etc). I drive mine everyday and winter here is minus 20c or lower and I get heat enough to clear the windscreen and warm the cab (110 CSW). For more heat I also have a Wabasto diesel heater... yes the heater gets hot without it turned on. I also installed the digital fan control switch which spins the stock fan a lot better with more airflow. See info on this install here: http://www.defender2.net/forum/topic42251-15.html
In short, the heater should work well enough, its not normal to be tepid rather than warm to hot. Good luck. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks all, will report back my findings
