![]() | Home > Puma (Tdci) > Boost and EGT Guage Installs |
You don't have to have a phone app for displaying the OBD information, something like an Ultraguage will mount in the little gap in the middle of the instrument cluster and display all sorts of interesting information. Looks very neat and works well.
However nothing will display EGT because it's not monitored on the Defender so you'll have to add your own sensor. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
EGT can be measured on the 2.2 with an ultragauge as it has two temp sensors pre and post DPF, this is how I know mine is regenerating and not to turn it off. Also measures cylinder head temperature...
Also mounted it inside the clocks... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
![]() Click image to enlarge[/URL] You can see the EGT here, as CAT C Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Instagram - @r22oyp Roy |
Manxie Member Since: 29 Oct 2016 Location: Isle Of Man Posts: 26 ![]() ![]() ![]() |
I just ordered one of these today from Redarc, they get very good reviews and are quite unique in how the work as an LCD screen, they are also metric on the EGT in degC, and in PSI for boost, which I like. https://www.redarc.com.au/monitoring-gauges-g52-bea
toby9946 Member Since: 23 Sep 2015 Location: Hampshire/London Posts: 96 ![]() ![]() ![]() |
How do you mount the Ultraguage inside the dash? Is there a guide somewhere as I haven't found anything? -2015 Defender 90 XS Landmark-
Defender2014 Member Since: 25 Aug 2014 Location: Buckinghamshire Posts: 65 ![]() ![]() ![]() |
Found this.
Looks like a fair bit of work..... http://defender90xs.blogspot.co.uk/2014/09...ation.html Defender Puma 110XS SW Kawasaki ZX9R El Suzuki RGV250M Honda CB250N Super Dream |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
It's not as bad as it looks, just a bit delicate.
Well worth the effort though. Here's how mine turned out.. ![]() ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Your fuel level - is it picking it up through the actual fuel sender or doing guesswork based on the MAF?
