Home > Maintenance & Modifications > Ignition live Aux fuse box
Profyaffle
Hello,
I want to install an aux fuse box in the battery box. However I want it to be powered only when the ignition is on. It will only have heated seats, heated windscreen and radio eventually.
I am going to fit a 70 amp relay on the +ve wire so what I would like to know is what size cable will be suitable for the ignition live connection which I will feed into the battery box.
Many thanks.
Post #575497 4th Nov 2016 7:44pm
leeds
Once you go onto larger CSA cable you are looking at 7 -8 amps per mm2.
So for 70 amp the minimum cable size would be 10mm2 Going larger say 16mm2 will give you a decent safety margin..
Blue Sea do a split 12 gang fuse box. One set of 6 can be permanent live another bank of 6 can be iginition live only. Available [url=http://www.4x4overlander.com/product/blue-sea-st-5032-12-way-split-blade-fuse-block/]here[url]
Brendan
Post #575500 4th Nov 2016 7:59pm
Profyaffle
Thanks Brendan,
I have a larger cable to use from the battery to the relay and then on to the fuse box, it was just the size of cable from the switched ignition to the relay I wasn't sure of, does that make sense ? Embarassed
I have seen the blue sea fuse box but I have unfortunately already bought just a normal one.
Post #575501 4th Nov 2016 8:04pm
Mo Murphy
You won't need much to operate the relay, less than an amp so you won't need much in the way of wire.
HTH
50 Shades of Pennine Grey
Post #575533 4th Nov 2016 9:42pm
Profyaffle
Ok, thanks Mo. I will run a cable in now while I'm doing the cab interior.
Thanks again
Julia
Post #575572 5th Nov 2016 7:29am
